Newest Prophet 12 OS - BETA Main OS v1.4.2.3
cbmd
  • 515
    • Sequential
« on: April 03, 2017, 01:33:33 PM »
ALWAYS BACKUP YOUR IMPORTANT WORK VIA SYSEX DUMP BEFORE ATTEMPTING ANY OS UPDATES!!
Not that we're expecting bad things to happen, but always better safe than sorry. Just remember, you're never going to say to yourself "Man, I wish I hadn't backed that up..."
We do not recommend using the following MIDI interfaces for sysex transfers as we have had multiple users experience problems with them:
  • Native Instruments Maschine
  • Digidesign Mbox/Mbox2
  • Digidesign 001/002
  • CME U2MIDI
Updating the Prophet 12 OS on a PC
Updating the Prophet 12 OS on a Mac
To check if the OS update was properly installed, go to the global menu by hitting the 'Global' button and the OS version is displayed at the top of the 3rd column
If your OS update failed:
  • Update your MIDI drivers for your MIDI interface to the latest or last known stable version
  • Try alternate speed settings: transfer speed settings as low as 25% and as high as 100% have worked for some users when 80% did not
  • Try an alternate MIDI interface. The M-Audio MIDI Sport Uno works well here and is relatively cheap
  • In Windows with MIDI OX on Windows XP:  Try doubling or quadrupling the Size setting to start, and halving/doubling the number of buffers
  • Search google and/or forums for the company that produces your MIDI interface to see if other users are having similar problems with Sysex transfers and whether there is a solution specific to your interface
  • If you are on Windows XP, try another OS or machine. Although it's not ideal, we have had less problems with Mac OSX and Windows 7. Windows XP has known issues with sysex transfers
OS 1.4.2.3 has become the latest official OS. You can download it at the bottom of this post or from our website:
Prophet 12 Keyboard OS
Prophet 12 Module OS
BETA Main OS 1.4.2.3
  • Bug Fix: Writing a program sending out program NAME NRPNs
  • Bug Fix: Split/Stack active, pot mode pass thru, when pot is made active on one layer, it becomes active on the other layer
  • Bug Fix: Clock set to Slave Thru, no MIDI clock passed to MIDI OUT port
  • Bug Fix: non zero value on slider prevents unit from booting
Main OS 1.4
  • NOTE: Reset globals or enable the screen saver global after installing this OS unless you absolutely do not want it on to save your OLED lifespan
  • This is the official release. It is identical to the 1.3.5b OS except the version number has been incremented to 1.4
Main OS 1.3.5b
  • Release candidate
  • Fixed bug: Corrected Global Calibration menu items
  • Fixed bug: Corrected Unison Detune behavior for Multi Mode
Main OS 1.3.2
  • Release candidate
  • Fixed bug: Corrected Osc. 3 Slop behavior
  • Fixed bug: Corrected UI behavior for when Global Dump Request received
  • Fixed bug: Corrected Unison Detune behavior for Stack/Spilt/Multi Mode
  • Fixed bug: Corrected Mod Amount pot behavior in Relative Pot Mode
  • Fixed bug: Some global params not sent as part of a Global Dump
Main OS 1.3.1
  • Release candidate
  • Fixed bug: Audio mod now works correctly as a mod source
  • Fixed bug: DC mod not stacking correctly when applied to filter cutoff
  • Fixed bug: Linear FM was not DC filtered correctly
  • Fixed bug: Osc FM and AM send junk data when synth set to CC
  • Fixed bug: Values sometimes jump when using filter cutoff pot
« Last Edit: February 11, 2020, 12:07:40 PM by cbmd »
Product Designer
cbmd
  • 515
    • Sequential
Re: Prophet 12 BETA Main OS 1.4.2.3
« Reply #1 on: April 03, 2017, 01:33:51 PM »
New Prophet 12 BETA OS posted!
Product Designer
