Tempest App Editors
Tempest App Editors
« on: March 30, 2017, 04:58:59 PM »
A very useful thread for all Tempest users out there...Support these people if you find a way ;)
Attached files can be found at the end of the 1st post after you logged In..
Max4Live editor from Arnaud
http://www.maxforlive.com/library/device/3425/tempest
Max4Live CC randomizer from Nywknh
http://www.maxforlive.com/library/device/4024/tempest-cc-randomizer
Max4Live Tempest Step Randomizer from randomknobs
https://gumroad.com/l/TSteprand
Have Fun!
« Last Edit: August 16, 2020, 05:25:09 AM by Yorgos Arabatzis »
Re: Tempest Software Editors
« Reply #1 on: October 28, 2017, 04:29:52 AM »
Hello there, here is a new random CC step sequencer..
check it out!
https://youtu.be/rgXEtdsoBvI
« Reply #2 on: October 28, 2017, 05:28:02 AM »
Thanks for posting it!Looks interesting!I’ve updated 1st post with it ;)
check it out!
« Reply #3 on: December 11, 2018, 06:10:49 AM »
Is there a PC editor? I’m losing my studio space and I’d like to keep my Tempest, but it may have to go if I can’t find a way to control it from a place that’s not easily accessible.
You can't make everybody happy, but you can make everyone miserable.
« Reply #4 on: December 11, 2018, 06:45:40 AM »
Only ArnaudLaPret Max4Live patch that's attached in the 1st post i'm afraid...
« Reply #5 on: December 15, 2018, 02:19:17 PM »
Creating a kind of "remote control" for Tempest is simply not possible... It does not have the necessary MIDI control for this.
The main lack is in realtime controllers like CC's... There are simply not enough of these, and those that are there only allow for control of the few beat wide parameters... The sliders do not even send out CC'S!
The only way to control all the data are by SysEx, and here it gets even worse. Only the currently selected sound can be dumped to Tempest, but not requested. Same goes for the current beat, but beats are packed data even beyond the usual SysEx packing scheme, so you would need special software to unpack these and obtain the algorithm from Sequential... Projects are the same, and the sheer size of such a dump is huge.
So forget about ever seeing any editors that will remote control Tempest, it will not happen. The best you will see is a sound editor as this data type is the only one not packed, and even these will be crippled since you cannot dump the sound to any of a beats 16 sounds chosen from the editor... It will allways dump to the currently selected sound you have initialized by pressing the appropriate pad. Also, you cannot change any beat parameters from that editor, so all of those must be changed on the interface.
I have made an editor for sounds using the old Soundiver program from Emagic, but it suffers under all these things I just mentioned, but it does ease the creation of single drumsounds though... Also, any such editor has to dump all single parameter changes as one whole sound as there are no SysEx or CC for changing single parameters... Luckily this is not a problem thru USB because it is very fast, but this will not work using MIDI DIN ... The Tempest has a critical SysEx bug in its MIDI DIN code that DSI decided not to fix when i reported it years back now.
MIDI implementation in Tempest is in my opinion one of its worst design flaws of all second only to user sample support.
I know this is not what people want to hear, but its the truth... You just have to let that sink in, and enjoy what IS there 🙂
« Last Edit: December 15, 2018, 02:23:25 PM by Razmo »
KoSv
« Reply #6 on: December 21, 2018, 04:21:11 PM »
sounds are packed too.
Classical piano drilled.
Jazz disillusioned.
Technoid.
KoSv
« Reply #7 on: December 22, 2018, 03:53:35 AM »
OSX CC randomizer from Van
http://kosv.github.io/TempestSysexOSX/
Have Fun!
hey Yorgos, "OSX CC" randomizer is missleading. This is a sound sysex thing. but anyway, the link is down due to the fact that I'm coding and soon releasing a new sound generator that is much more stable and multi platform compatible with much more features.
cheers and happy chrastmas :)
Jazz disillusioned.
Technoid.
« Reply #8 on: December 22, 2018, 06:03:16 AM »
Thanks for the heads up Van!Looking forward for your creation!Happy Xmas to you too ;-)
Have Fun!
« Reply #9 on: August 17, 2026, 09:54:15 PM »
It turns out, you can do a little better than that.
https://www.bitrotten.com/tempest/editor/
