Noticed that version 1.3.0 was out on the SoundTower site, so I installed it. Was hoping they had addressed the problem with the Effects not being reflected correctly between the screen and what's selected on the OB. No joy... still out of sync.
I went ahead and bought both the standalone and the PlugSE (a $30 gamble) without much testing, although the setup was pretty straightforward and worked just like the instructions.
Regarding the effects, the order that Soundtower displays is in the same order as the effects are listed in the printed manual...except for the reverbs, the manual lists the effects in alphabetical order:
EFFECT A
bbd-ddl-CHO-FL1-FL2-PH1-PH2-PH3-rin
EFFECT B
bbd-ddl-CHO-FL1-FL2-PH1-PH2-PH3-rin-HAL-r00-PLA-SPr
On the actual OB-6, the order is (listening to these it is obvious they are correct!):
EFFECT A
bbd-ddl-CHO-PH1-PH2-PH3-rin-FL1-FL2
EFFECT B
bbd-ddl-CHO-PH1-PH2-PH3-rin-FL1-FL2-HAL-r00-PLA-SPr
Other misses I have discovered.
LFO SHAPE top position is "SINE" on hardware, "TRIANGLE" in software (I mistakenly reported that the position was missing on my earlier report)
I just went through and checked everything else and these are the only things that popped up, although I have also noticed a couple of glitches here and there like the LFO SYNC, although that seems fine with 1.4.0 (which I am currently running and still has the specific issues listed above).
On a further saga...just gave up on an attempt to use the PlugSE. I had mixed results...first I tried it with Reaper and could not get it to work at all...it would not recognize the OB-6 at all, even though it is clearly connected as the standalone version works fine. Neither of the red lights in the MIDI port selection would come on and a scan reported that it could not find my OB-6.
Then I tried it with Cakewalk SONAR (the final release of the Platinum version), and everything worked fine...the PlugSE fired up properly, recognizing both input and output (both red lights came on) and seemed to work well. Unfortunately, I'm using SONAR less and less since the debacle with Gibson when I decided to try out Reaper, which I am liking.
Then I tried it with Ableton LIVE which I use mainly for idea generation and jamming for song fodder...I was able to get the OB-6 input connection (i.e. I could use the software interface to program and load the synth), but could never it to synch up with the hardware controls. Oddly the red light that indicates successful connection (I think) came on in the <MIDI Out Port> selection, but <MIDI In Port> stayed dark (the opposite of what actually was happening as I was able to send stuff TO the OB-6 FROM PlugSE, but could send stuff FROM the OB-6 TO the PlugSE)
Any thoughts??
