White noise not very random.
« on: March 27, 2017, 09:06:13 PM »
Hello all. New owner of an OB6 Desktop here. I love this synth very much. But one thing I've noticed is the white noise sound source isn't very random, we can sometimes hear faint repeating patterns in the noise. I would think that on an instrument in this price range, the white noise sound source would be absolutely random ?
Mind you, it's nowhere near as bad as the dreaded MM5837 digital noise chip from the early eighties, but still not completely random as in a genuine analog white noise generator (à la Oberheim SEM).
Maybe something correctable in an upcoming firmware revision ?
DavidDever
  • 698
  • Audio Software Developer
Re: White noise not very random.
« Reply #1 on: March 29, 2017, 03:06:08 AM »
Huh? No such thing. Are you sure that you're not confusing this with the OB-X (also a MM5837)?
This might be helpful: http://electricdruid.net/wp-content/uploads/2015/07/NoiseGen1Datasheet.pdf
Note that the Electric Druid uses an algorithmic noise generator, which is what I suspect that DSI uses as well.
« Last Edit: March 29, 2017, 03:24:54 AM by DavidDever »
« Reply #2 on: March 29, 2017, 10:26:21 AM »
Sorry, my bad. I should have referenced the Minimoog D, (or any other transistor, or diode reverse bias white noise sourced synths) not the SEM which does not offer white noise.
The same problem was discovered on Behringer's DeepMind 12 in earlier OS version of the firmware. It has been since corrected and now the synth has a much better white noise source, devoid of any discernable audio patterns.
In this day and age of super fast DSPs, I can't understand why generating endlessly changing, and non-repeating random values can't be so hard to program ?
« Last Edit: March 29, 2017, 10:36:56 AM by AlainHubert »
« Reply #3 on: April 03, 2017, 04:07:05 AM »
true random can repeat as much as it wants!
« Reply #4 on: April 04, 2017, 09:43:27 PM »
You will NEVER hear any repeating pattern (a sequence of digital numbers) in analog white noise.
White noise is defined as all audio frequencies simultaneously. Not a digital memory buffer of fixed length being played twice in a row every two seconds...
