I recently acquired a new P'08 desktop PE edition and am having some problems with the pots: sometimes the pot will be all the way right to its max position but will have an actual value that's less than the max. At that point I have no way to go further right and have to go back left and then right faster to reach the actual maximum value, almost as if it were an encoder...So I'm a little puzzled. Did that happen to others? Am I missing something?
You can see an example with the attached photo: the resonance pot is all the way to the right, but the actual value is stuck at 96.
Thanks a lot
