***edit, I’ll leave my original reply below, but I just realised the previous reply question wasn’t from the other poster and you had not misunderstood what I’d said at all but were just posing another question, apologies for MY misunderstanding.
In answer to your question.... I don’t know, but you’ve got me curious so I am going to try it
. EDIT2, doesn’t work.
Sorry, I meant that the mod wheel is set in that patch to raise the ‘amount’ on LFO4 which in turn is set to increase the amplifier envelope amount, which I believe is causing the amplifier to overdriven leading to the clipping of the signal,so just turning down the amp env amount won’t help if you’re using the mod wheel.
BUT...while turning them down certainly gets rid of it on mine, upon a further play I think Drive, which is set to 84, is actually the main culprit in that patch. Turn that off and it’s gone even if you leave the amp env at full. If you want Drive in the mix then the amp env needs to be lowered and so does the mod 1 if you’re using the mod wheel.
