You know the little led dot that shows up in the display when you are tweaking a knob and that knob reaches the saved value of that parameter. Well yesterday I noticed this dot was on constantly no matter what I was doing. Changing presets (user and factory) and the dot just remained lit. I was able to make it stop with a power cycle and it hasn't happened since. Anyone seen this before?
It's a bug. Mine does the same.
Basically, what happens is if you edit a patch and set a parameter that makes the dot visible, the dot will normally disappear after a couple of seconds. But if you CHANGE PATCHES while the dot is still visible (in those couple of seconds before it goes away), then the dot remains visible at all times (until you turn a knob to remove the dot).
