Toggle navigation
Home
Help
Search
Login
Register
Login
Register
Close
Login
Remember me
SEQUENTIAL/DSI
Prophet
Sequential Prophet-6
Question about P~6 lowpass filter
Print
Pages: [
1
Jonas Sjöström
14
Prophetate the world of music!
on:
November 18, 2015, 09:15:35 AM »
Hi
I have a question regarding the lowpass filter on the amazing prophet~6, does it have the boost function on it like you can do on the Pro-2 but fixed? I.e. so it doesn't loose volume when setting resonance high? If so is it possible to disable it, like is there a jumper setting to switch between "boost" and "non boost"?
/Jonas
Drumtraks, Poly Seq, Mopho, Pro-2, Prophet~5, Prophet~6
Paul Dither
2627
Re: Question about P~6 lowpass filter
Reply #1 on:
November 18, 2015, 10:25:24 AM »
To my knowledge, the boost option is exclusive to the Pro 2's low-pass filter.
Jonas Sjöström
14
Reply #2 on:
November 18, 2015, 11:11:00 AM »
Hi Paul, True except for the curtis eurorack filter which has the boost switch. But on the pro-2 you can manually set the amount. And I thought maybe the have put a fixed boost on the P~6?
Paul Dither
2627
Reply #3 on:
November 18, 2015, 11:12:34 AM »
True, I forgot about the module. But I haven't read anything about a boost option in the Prophet-6 manual, so I would assume it's not there.
Jonas Sjöström
14
Reply #4 on:
November 18, 2015, 11:31:04 AM »
You might be right
just that I got the impression when adding alot of resonance the filter it behaves like if the boost function is applied but I haven't found any info about it either but thought I'd ask at least
thanks for your replies!!
Paul Dither
2627
Reply #5 on:
November 18, 2015, 11:40:14 AM »
No problem. - I guess only the Sequential team can tell what's going on "behind the scenes."
Jonas Sjöström
14
Reply #6 on:
November 18, 2015, 11:43:32 AM »
Haha right
Print
Pages: [
1
SEQUENTIAL/DSI
Prophet
