Newb question: When I'm in 16 sounds mode, is there a way to assign a different default pitch to a pad without changing the tuning of the oscillators? I basically want it to play a pitch that I can currently only hit by going into 16 Tunings mode.
Thanks.
Why don't you want to change the pitch of the oscillators? I mean, you've just cited two very reasonable options, both of which were specifically implemented to facilitate this very scenario:
1) Play the sound in '16 Tunings' mode, effectively allowing you to transpose the sound to any pitch at any time.
2) Tune the oscillators such that your sound has the base pitch that you need directly from the pads in '16 Sounds' mode.
And if you need both, that's why you have
32 pads to play with: i.e. simply copy the sound to two different pads, keep one tuned to middle 'C' or whatever, and tune the oscillators on the other to whatever pitch you need as a one-shot.
I'm not seeing the problem to be honest.
Cheers!
