Newest OB-6 OS - v1.7.4
« on: March 08, 2017, 10:59:14 AM »
This OS is compatible with both the keyboard and desktop module; it will display as "1.7.4" after the update. The OS update may hang on "1" after the second countdown. If the OB-6 does not reboot automatically after the second countdown, wait 60 seconds and then power cycle.
ALWAYS BACKUP YOUR IMPORTANT WORK VIA SYSEX DUMP BEFORE ATTEMPTING ANY OS UPDATES!!
Not that we're expecting bad things to happen, but always better safe than sorry. Just remember, you're never going to say to yourself "Man, I wish I hadn't backed that up..."
We do not recommend using the following MIDI interfaces for sysex transfers as we have had multiple users experience problems with them:
  • Native Instruments Maschine
  • Digidesign Mbox/Mbox2
  • Digidesign 001/002
  • CME U2MIDI
Updating the Prophet 6 OS
To check if the OS update was properly installed, restart the unit and the version number will be displayed on startup in the bank/program LCD
If your OS update failed:
  • Update your MIDI drivers for your MIDI interface to the latest or last known stable version
  • Try alternate speed settings: transfer speed settings as low as 25% and as high as 100% have worked for some users when 80% did not
  • Try an alternate MIDI interface. The M-Audio MIDI Sport Uno works well here and is relatively cheap
  • In Windows with MIDI OX on Windows XP:  Try doubling or quadrupling the Size setting to start, and halving/doubling the number of buffers
  • Search google and/or forums for the company that produces your MIDI interface to see if other users are having similar problems with Sysex transfers and whether there is a solution specific to your interface
  • If you are on Windows XP, try another OS or machine. Although it's not ideal, we have had less problems with Mac OSX and Windows 7. Windows XP has known issues with sysex transfers
INSTALLATION NOTE: It is recommended reset globals after installing a Main OS update (GLOBALS + WRITE)
Main OS 1.7.4
  • Bug: Pitchbend Sends Incorrect MIDI data when MPE Enabled
  • Bug: Received Poly Aftertouch commands glitch
  • Bug: Resolved issues with Aftertouch Curve #7
Main OS 1.6.6
  • Feature: New improved aftertouch curves
  • Bug: Pitchbend not working correctly with MPE active
  • Bug: Arp/Seq note output active, stopping sequencer not sending note offs and causing hung notes
  • Bug: Polychain on, Unison chord mode on, playing notes B6 and above cause program change messages to be sent from MIDI out
Main OS 1.6.4
  • Feature: MPE support
  • Feature: Slop now supports normal slop or Vintage operation
Main OS 1.5.8
  • Fixed bug: Improvements to ARP BEAT SYNC operation
  • Fixed bug: CC5 sent from portamento mode parameter.  Now sent from RATE parameter
Main OS 1.5.5
  • Fixed bug: with no external clock present, arp beat sync on, arp does not quantize
  • Fixed bug: record on/off NRPN not being responded to
Main OS 1.4.9
  • Fixed bug: LED consistency improvements
Main OS 1.4.1
  • Fixed bug: Correct brightness inconsistencies with small rectangular LEDs
  • Fixed bug: Additional Polychain improvement
Main OS 1.3.7
  • Feature: New Global Param: Arp Beat Sync On/Off. Global row 2 number 9
  • Feature: MIDI Out for the Arp/Sequencer - Param Xmit Global options CAS (CC + MIDI Out for arp/seq) and nAS (NRPN + MIDI Out for arp/seq)
  • Feature: Sequencer now transposes from keyboard/MIDI notes on UNISON patches
  • Fixed bug: Improved Polychain implementation and fixed bugs
  • Fixed bug: Various small bug fixes
Main OS 1.2.0
  • Fixed bug: Resolved a fringe issue causing a very small number of units in the field to intermittently fail to produce audio or to have static noise in the digital effects
« Last Edit: December 15, 2021, 05:50:03 PM by extempo »
SEQUENTIAL
Re: Newest OB-6 OS - v1.7.4
« Reply #1 on: December 15, 2021, 05:51:21 PM »
OB-6 OS Version 1.7.4 has been released and is available at the Sequential support page:
https://www.sequential.com/updating-ob-6-os/
You may need to reset your globals after the update (GLOBALS + WRITE).
SEQUENTIAL
