Thank you for that thread, but I'm not sure it totally answers my question. I am sorry if this is a simple fix/issue.
I am using six patch cables from each of the six voices to six inputs on my USB interface (Scarlett 18i8). I use voice assign to assign the first six pads to V1, V2, etc. My workflow is that I program a MIDI sequence in Ableton, output that to the Tempest, and then record the six channels of audio in the DAW. I like working this way because I want to be able to mix the Tempest sounds (EQ, pan, etc.) in post-production, rather than onboard. So I would like to be able to get the sounds at their normal volume by leaving them panned in the center on the Tempest (because panning to the sides seems to produce some ugly distortion/level issues/affect the timbre), and then just do the panning in my DAW. Is there a simple setting option I'm missing to switch to stereo so that the outs can be at a normal volume when panned neutrally? Or should I just hard pan all the way to one side and lower the input gain on my interface to adjust?
Also, separate question -- is there a way to save a bunch of sounds at once? Like I create a drum kit of six sounds, and then I save them all in one project to be loaded instantly? I thought "Project Save" was the way to do this, but all my sounds get lost when I do this.
Thanks, sorry if this is noobish.
