Hello there.
My first time here. I registered because I wanted to know as much as possible about the synth before buying it. I hope you can help me a bit
I wanted it since it came out but at that time I went for Sub37. It looks like the time finally came to combine them
For a long time I had a feeling that this beast would be perfect for cutting through massive Sub37 frequencies. Hopefully somebody here has them both, would really appreciate any comment.
This is what's going on in my mind at the moment:
1) Can the sequencer record incoming midi notes realtime (for example sequences from iPad)? With realtime I mean that it records while it is running so you get the same sequence with rests and other stuff as the source sequence. What about other incoming data?
2) Somewhere I read that the sequencer stops when you tweak parameters while it is running. This one seems quite strange to me but I have to ask. True?
3) I want to use it also as sequencer for Sub37. With Pro 2’s CV outs I would like to modulate Sub37’s Filter CV, Volume CV, KB Gate CV. I assume notes would be easier to send via MIDI. Does anyone have some experience with these two synths connected in a similar way?
4) Anybody sending sequences from it to iOS apps?
Thats it for now, probably something else will pop up eventually;)
Cheers and thank you!
