New sequencer destination: Note to CV# out
On the sequencer, the current "CV#" destination allows selection of a value from 0 to 127 be output as a scaled voltage 0-10v. The idea/request is that in addition to that, there's a second destination source "Note to CV#". The UI is the same as the note selection on sequencer track 1, but instead of those notes being played through the Pro 2, the notes are sent as 1v/octave out the chosen CV port. Bonus if the notes can be input via the Pro 2's keyboard.
I haven't tried it yet, but I suspect this is technically possible to achieve now by running the CV out through a quantizer module. The current CV out track allows selection of a value 0 to 127. At 1v/octave, it means each octave has roughly 12.7 values which more or less line up to the 12 semitones per octave. Outputting a C4 probably means a quantizing a value of around 50 (12.7 * 4); outputting C5 would be quantizing 63 (12.7 * 5). Having it be a part of the synth's UI removes not only the approximation and math to determining the output voltage, but also (potentially?) removes the need to have one or more quantizer modules to perform that.
