Which of these DAWs do you feel has tight sync with Tempest?
dsetto
  • 382
« on: February 07, 2017, 04:45:53 PM »
Hi. Which of these DAWs do you feel has tight sync with Tempest? Live, Logic, Cubase, Pro Tools.
Thank you.
idm
Re: Which of these DAWs do you feel has tight sync with Tempest?
« Reply #1 on: February 08, 2017, 01:15:13 AM »
Tried with Studio One, but Studio One's midi implementation is buggy, so I now moved on to use Ableton as my main DAW for production and live use. So far it's tight as a rock.
« Reply #2 on: February 08, 2017, 04:19:15 AM »
+1 for Live...In tips & tricks thread i wrote:
"To anyone searching for a tight sync between Ableton Live & Tempest if you own an iOS device with the free Midi Link Sync app and this adapter http://www.apple.com/shop/product/MK0W2AM/A/lightning-to-usb-3-camera-adapter
you can have a very tight sync using Ableton's Link feature  ;) "
The above method is excellent cause you can use Tempest as the master and even if you make drastic changes in tempo Live follows instantly..
« Last Edit: February 08, 2017, 04:22:18 AM by Yorgos Arabatzis »
« Reply #3 on: February 08, 2017, 05:19:27 AM »
I use it with Pro tools, perfect couple ;)
« Reply #4 on: February 08, 2017, 12:14:20 PM »
Never had any issues with the latest version of Logic + Motu XPress
« Reply #5 on: February 08, 2017, 06:33:44 PM »
Also sync improves when there is hardware monitoring. Monitoring through a mixer opposed to monitoring thorugh an audio interface and DAW. I got a pretty tight sync in Live this way and also adjusting midi clock sync delay in the preferences. Id record the tempest metranome and then ajust the sync delay. I got it tight, but then it would kinda drift out of sync after a couple of mintues. I like ableton link, but it doesnt always work for me. I think if the router has a lot of traffic that messes it up. Ive also done the adhoc  network, but sometimes it doesnt work either.
« Reply #6 on: February 08, 2017, 06:35:42 PM »
I'm using the Tempest with Digital Performer 9, so far no problems.
https://soundcloud.com/the-aural
https://www.facebook.com/auralproductions/
Ensoniq SQ80, Kawai K5, Yamaha CS6x & DX200, Alesis ion, Akai Z4, DSI gear: {Evolver Desktop, Poly Evolver Keyboard, Mopho x4, Tempest}, Waldorf Blofeld & Streichfett, Moog Freqbox, Roland R8 & R8m
dsetto
  • 382
« Reply #7 on: February 09, 2017, 12:20:32 AM »
thanks, all.
dsetto
  • 382
« Reply #8 on: February 10, 2017, 10:46:11 AM »
Speaking of grapevines, .... Someone told me Cubase has a tighter MIDI clock.
dsetto
  • 382
« Reply #9 on: February 13, 2017, 09:33:27 PM »
Has anyone experienced that?
« Reply #10 on: February 18, 2017, 07:01:47 PM »
+1 for tight clock in Live with win7 64 via usb. Wifi and link has its own added latencies, so I don't bother when it matters. It swings less than +-.5 bpm each way, and thats damn good for analog gear on a latent windows setup. Maybe not perfect tight, but definitely (as a drummer) close enough to not be thrown about on it. Processing latency is usually worse. THis coming from a fan of NOT using quantatize much.
« Last Edit: February 18, 2017, 07:06:05 PM by Shanesplanet »
« Reply #11 on: March 08, 2017, 05:55:24 AM »
Works like a charm with Logic X and a motu Track 16. My advice, buy a cheap Berhinger ADAT to get all the separate outputs for extra daw treatment after ; )
soundcloud.com/tainsus
dsetto
  • 382
« Reply #12 on: March 08, 2017, 11:25:10 AM »
Thank you for the responses. I remain interested in your experiences, even if this thread has been inactive.
