I hate to reply with a less-than-definitive answer or what could be wrong information, but as I seem to recall this can be an issue if you use balanced cables in Tempest's unbalanced outs.
I remember reading something on the old forum when Tempest first came out, and while previously I'd never given a second thought to using balanced cables with unbalanced outs, ever since then I've made a point of only using TS cables with my Tempest, like it's somehow not as forgiving with a TS/TRS mismatch as other gear seems to be.
Anyone else remember this? And please correct me if I'm wrong!
Considering that I was the guy who answered a lot of these questions on the old forum, I'll weigh-in here once again and say that
most of the confusion regarding the use of balanced vs. unbalanced cables, over the years, has had to do with the individual voice-outs being stereo, and people not understanding the difference between stereo vs. balanced cables and connections, and how that differs from the main-outs being mono, unbalanced, etc. And I'm not going to explain it again (smirk).
Ahem!
Sufficed to say, I suspect that most of these so-called "phase" issues that people are reporting are entirely user error, and have nothing to do with the hardware itself. So if you are experiencing phase-cancellation or comb-filtering anomalies, chances are it's you, not your Tempest (wink). Check your monitoring, check your cables, check your sound design, and be sure you fully understand your signal path...
Cheers!
