I have a problem with my Pro 2 and Pro Tools .
All seem ok, the Pro 2 is in Slave mode, midi , and Pro Tools send the midi beat Clock.
When i play a sequence in Pro Tools, i have only the first note and nothing else.
Second problem, i try it with USB .
I ask to Pro Pool to send the midi beat Clock on the USB port, no problem.Pro tools play a sequence, but there is a problem of syncro if a use the Pro 2 sequencer . if Pro tools play a loop ( for example 4 bars), i see and i hear that the sequence is not sync along Pro Tools play.
I'm very sorry for my bad English written, but i'm french
Thank you in advance because it is a big problem for me.
I would like to use the midi and not the USB, if it's possible.
I have no sound if i try to use both Midi and USB for Sync.
