Hi!
I searched an answer to my problem which was about Prophet 6, not OB6. Anyway I found this thread and someone mentioned about switching to midi cable instead of using usb. I tried using only midi cable, not with the usb, but with a midi cable thru midi interface. And so far my pro6 is working as expected, not a single freeze since. So, thanks, and hope this thing gets fixed for everybody else too!
Globals are set as follows:
Midi Channel: 16
Midi Clock: nSS
Clock Port: Mid
Parameter Tran: NR
Parameter Rcv: NR
Midi Control: On
Midi Sysex: midi
Midi Out: midi
Local Control: off
