If you're looking for REALLY tight sync, make sure to quantize your trigger notes.
It's also worth pointing out that Logic's own EXS24 sampler can be used to trigger a sample per note, which you can then use to line up against the recorded audio from an external MIDI-synced slave to tighten (or loosen!) up the feel.
