Have you tried the suggestions pertaining to power?
"Try changing your plug configurations for the synth and your laptop/computer, i.e. try unplugging your laptop from the wall and see if the problem still exists, and try plugging your DSI synth and the computer into the same outlet. You can also try using a surge protector/power conditioner, try powering your audio interface with a wall plug if it is bus powered normally."
