SEQUENTIAL/DSI => Prophet => Prophet Rev2 => Topic started by: sonofagrump on February 07, 2018, 10:03:04 AM
When I reset to a basic patch, if I have two dual quarter inch cables plugged into both output A and output B in stereo, the audio in the headphones goes in and out. As soon as I unplug the 1/4" cables, the audio remains steady in the headphones.
What is happening? I would assume the headphones just output everything. I suppose that's incorrect. So at the very least, why does it fade in and out?
Thank you!
Best,
Devon
I have the same experience with some patches also when only out B is connected. (nothing in A) Sound moves from headphone to channel B and vice versa. Did you find the cause ?
DSI confirmed, when you plug in anything in the B outputs, the B sounds get physically disconnected from A and the headphone only outputs what is on A. So, perhaps what you experience is the missing B layer sounds on the headphone.
Also, DSI confirmed, you will only hear 8 notes play back on a 16 voice unit when playing a single layer (Stack/Split not enabled), and with multi-mode disabled. In my experience this results in 8 notes using layer A and then the next 8 notes using layer B getting the effect of "dropped" notes on the A or B output. In other words... not sure how you can force 16 notes polyphony on one layer in non-stack/split mode.
Perhaps it would be a nice feature to be able to select the number of voices per layer AND to select to which output the layer A and B sounds go. (A only, B only, A+B)
To be clear, you get 16 voices on a single layer, A or B, if you're not using stack or split as long as you do not have any cables plugged into the B outputs. i.e. if you're connected to the main outs. There's no reason for you to ever be connected to the B outputs only, so if you're using the B outs then it means you want to process layers A and B separately or run in a bi-timbral configuration.
With Jacks in A+B, No split or stack playing same or notes in sequence (with note off in between), 8 notes of layer A output to jack A and the next 8 notes of layer A output to jack B. The same occurs when selecting Layer B but then for layer B sounds.
Effects off, All mod routing offs, no ARP, multi mode off, no unison. Examples: U1P68.
How to get all 16 notes for Layer A to output on A without having to unplug the jacks from B?
You can’t. If you’re plugged into a mixer you have to monitor from there, the rev 2 headphone jack will only output layer A
Hope there will be a global settings feature to select between the current "alternate" output mode and a "fixed" mode which fixes all layer A sounds to output A and layer B to output B (16 voice polyphony) so that it is not needed to physically insert and remove jacks for the desired setup.
I’m not sure but it seems like it is done with physical switching jacks and not software.
This is correct.
