SEQUENTIAL/DSI => Prophet => Prophet '08 => Topic started by: jeffscottbrown on January 19, 2017, 08:46:03 PM
I understand that if nothing is connected to the B outputs then both layers A & B will come out of the main outputs.
If I only have 1 output cable connected to 1 of the main outputs, the other main output is empty (no cable connected to it) and both B outputs are both empty, is all of the sound routed to the 1 output that I have connected an output cable to?
Thanks for any clarification.
You can have the entire signal come from a single jack of the main output if you've set the instrument's signal to mono in Global.
Excellent. Thanks!
