SEQUENTIAL/DSI => Prophet => Prophet Rev2 => Topic started by: CGP25 on August 22, 2019, 09:38:07 AM
Hi Guys,
I'm quite new to the Rev 2 and synthesis in general, so I may be making a basic mistake, but I can't for the life of me understand what I've done wrong...
I recently started experimenting with using an expression pedal to control the cutoff frequency on the filter and now for some reason I can only control the cutoff with the pedal. When I unplug the pedal or change what the expression pedal controls, the cutoff knob has barely any audible effect on the frequency of the filter, even though the display is saying the filter is changing frequency with the turning of the knob. When I plug the pedal back in and use it to control the cutoff, the filter works fine again....
Does any one have any experience with this and know how to fix it?
Thanks in advance!
I vaguely recall having this issue when I still owned my REV2. Hit global and go to number 26 I believe which is reset globals. Then you might want to calibrate on top of that, which shouldn't be necessary, but I think I did that as well.
Thanks! Problem solved.
