SEQUENTIAL/DSI => Take 5 => Topic started by: ibiza on April 18, 2024, 06:56:15 AM
Hi All,
This is my very first post on this forum!
So, here is the deal; I have the chance to buy a near-perfect Take 5 for a VERY reasonable price. The thing is, I already own a P6 (which I love). Does it make sense to own both synths? Or maybe there is too much overlap? Are the OSC and the filter, etc the same?
For context I own the following; P6/OB6, Subsequent 37, Analog Four MK2 and the Novation Peak.
I’d love to hear your thoughts!
PS: I have to give the shop an answer by Monday;)
Hi All,
I am sure lots of people will say go for it, they are different synths etc.
My advice would be, do you really need another polysynth? You already have a P6, OB6, A4, Peak.. Would you be better off spending the cash on something else - effects, compressors, outboard etc? If the motivation for it comes from the fact there’s a good deal to be had alone that perhaps answers the question. Having said that, if it is a truly great deal you can always sell it on at some point if you’re not using it - up to you of course! But I would definitely think about if you really need that over something else before making the call.
Just my opinion, and whatever way you decide good luck and enjoy!
You might also ask over in the P6 forum if you haven't already. I've not played or heard a Prophet 6 so have nothing to add other than a recollection that some people here felt the T5 had a larger sweet spot, but double-check that because it may have been in reference to the Rev 2 and not the P6. ¯\_(ツ)_/¯
It might also help if you could describe your use-case -- I guess one reason to buy might be because you want to gig w/o taking a ton of gear.
Hi All,
Hi Ray,
That’s a valid point. As you pointed out, I don’t “need” another poly. But it’s hard to say no to 500$ off for what essentially is near brand new unit:D
With that said, I don’t want to buy it if it sounds to close to my P6… Hence my question.
Hi Francis,
Good idea. I will try to post over the Prophet 6 forums and see if someone is actively using both. I’m planning to use the T5 in the studio, so it’s just to add a different color to my sound palette.
