Brand new Pro 3 issue
Started by SMV, August 14, 2026, 03:38:22 AM
6 Replies 3,976 Views
SMV
Commerce
Logged
Hello,
2 days ago I received a new Pro 3 standard. I have a very strange issue, that happens randomly and sometimes.
Let's say I am in the mod matrix page, and the page goes on the filter section, without I touch any knob.
It happens rarely and totally random.
Did anyone have this issue?
Thank you
SMV
Elric
Full Member
Peak Oil
Logged
Quote from: SMV on August 14, 2026, 03:38:22 AM
Hello,
Thank you
Yes, this happens sometimes. The CutOff dial is the most common culprit but it can happen from other knobs as well. The knob does a late update to it's final/current position. You probably had recently changed the parameter (say, CutOff) and the position is "settling". The system will read a slightly different position and update the value, which switches the display to the Filter dialogue.
  I think this is why Sequential no longer displays parameter values for their synths. Something in the hardware or firmware does this, and it can be annoying. I don't know why other synths companies don't seem to have this problem.
:Elric:
SMV
Commerce
Logged
Thanks for your reply.
You got perfectly the point.
So do you think is not the case to ask for a warranty change?
Because as you wrote, it seems that is a common issue
SMV
Elric
Full Member
Peak Oil
Logged
Quote from: SMV on August 14, 2026, 05:59:32 PM
I'm pretty sure it's not a replaceable warranty issue, it's just the way the Pro3 works, I think it's just a Sequential thing.
I actually came up with a (dumb, diy) fix for it.  When you change the Cutoff and are going to go work on the sequencer, or something else, tap lightly around the filter cutoff knob to encopurage it to "settle".  :D   -- Then move on to other work
I've been really disappointed that the buyout by FocusRite hasn't meant getting some help on the Firmware/Software for Sequential. They obviously need it.
:Elric:
BT
Agents
Jr. Member
Logged
Please reach out to support@sequential.com. We can at least get you a new cutoff pot to install in the synth (it's quite easy and requires no soldering).
Sequential | Oberheim
SMV
Commerce
Logged
Thanks.
I contacted Thomann and I just today received a new unit. But there is another problem. One factory sound is corrupted.
Does anyone knows what is going on?
SMV
FedeB
Commerce
Logged
It happens to me too, I suspect it is some extra-sensitivity on one of the. knobs for filter section.
What happens is that as soon as you touch any control on the Pro 3, the display jumps to that control's page (something I REALLY WISH could be disabled).
So what must be happening is that as you manipulate the front panel to work on the mod matrix, perhaps some vibration triggers a microscopic movement on the filter section and you jump to that page on the display.
This is just my guess though.
I also had other synths in the past where knobs where constantly sending midi messages due to dirty contacts, something I was able to fix with a contact cleaner spray in one case, but which in another case required changing the potentiometer.
For me on my Pro 3 it doesn't happen often enough to be a real issue, but it is definitely annoying.
One partial solution I wish Sequential implemented was a threshold where a rotary control needs to move by a a couple of millimetres before it triggers the display change.
