Hey Guys!
Need your help on this setup
What works:
Midi controller----OUT---> 5 PIN Midi cable to ----IN--> REV2Desktop
Audio comes out to my interface. Normal playing
What does not work: Goal is to play Rev2 Desktop using my Studio Logic controller
Midi controller ----> Mac via USB Midi - Midi messages working fine - Chords played can be seen in Logic..Software instruments works.
Rev2 Desktop ---> Mac via USB Midi- Rev2 is present and may be selected as Midi Destination
Midi is tranmitting signal but no sound from Rev2. HOWEVER.. if I hit the "Play" button in Rev2 [sequencer].. audio comes out..
I recorded a midi track in Logic... but Rev2 is not playing it.
Global Settings in REV2:
MIDI Channel :All
MIDI Clock Mode : Off
MIDI Clock Cable : USB
MIDI Param Send : NRPN [tried CC /off]
MIDI Param Rcv : NRPN [tried CC /off]
MIDI Control : On
MIDI Prog Enable: On
MIDI Prog Send : On
MIDI Sysex Cable: USB
MIDI Out Select: USB
MIDI Artp+Seq: On [tried off]
Arp Beat Sync: Quantize [tried off]
Multimode : On [tried off]
Local Control : On
Obviously a routing issue here.
May I know what's the recommended Global midi settings in Rev2 Desktop?
Also any midi settings that I need to tweak in Logic pro x?
I do have a Pro3 which works fine. Also my Moog Sirin desktop works.
Any information would be much much appreciated.
Thank you!!
