Not sure if anyone else has an issue with the Midi Clock In not working after the 1.2.1 update? It was synced up to my Squarp Pyramid just fine before the update and now doesn't seem to be receiving the master clock properly. The Rev2 appears to be in Clock Slave Mode because you cannot adjust the BPM, but when I play the sequencer the Midi Clock functions like Arp and LFO syncing don't actually happen. The Tempo button also does not flash to indicate the external tempo. Can anyone help with this? Thanks!
