Hi everyone,
I bought a pre owned, mint condition Rev 2 a few months ago and have been trying to determine if two things I hear are defects or expected under normal operating conditions.
The first is a high pitched whistling tone coming from the synth itself when it is powered on, regardless of what else is plugged in, even if it’s just the power cord. It sounds like a dog whistle almost, not exactly loud but definitely audible and it’s annoying after a short time. I can hear it from 15 feet away easily. This seems like it could be just part of the synth operating normally but I wanted to check.
Second, when I use the headphone output, there is substantial background noise in the higher frequencies, with a peak above 10k that is especially noticeable. It is audible at every master volume setting. The photo attached shows the recorded spectrum with the default patch being played at 100% volume and the background noise is just as loud as the note itself.
The first issue I can live with, the second one is tough because I can’t play my synth with headphones without hearing it. I have reached out to support to see if these are normal operating features or if I’m dealing with an issue. Has anyone dealt with these? I don’t know if I’m just being overly critical… that’s what I’m trying to figure out lol. It is still under warranty and I’ve been dealing with it since day one so I’d like to find out if I should try to return it. I would gladly provide more information that seems relevant. I’ve done calibrations, plugged into a surge protected power strip, and changed outlets to no effect.
Thanks in advance for any help!
Jesse
