Tempest Main 1.5.0.2 and Voice 1.5 - Bug Reports
deepminddark
  • 28
  • I <3 my Tempest.
    • home®ecords label.
Re: Tempest Main 1.4.5.14 and Voice 1.5 - Bug Reports
« Reply #820 on: July 06, 2017, 12:09:09 AM »
Guys, please confirm if your "Click" metronome and BPM tempo speed up x2 after update to newest OS version 1.4.5.14?
Tempest for life.
« Reply #821 on: July 06, 2017, 01:51:49 AM »
I haven't noticed this, mine seems fine... under what conditions does it happen, such as when recording or playing back?
https://soundcloud.com/the-aural
https://www.facebook.com/auralproductions/
Ensoniq SQ80, Kawai K5, Yamaha CS6x & DX200, Alesis ion, Akai Z4, DSI gear: {Evolver Desktop, Poly Evolver Keyboard, Mopho x4, Tempest}, Waldorf Blofeld & Streichfett, Moog Freqbox, Roland R8 & R8m
blewis
  • 258
« Reply #822 on: July 06, 2017, 05:06:58 AM »
The 2x number would suggest a MIDI echo. Double check the update didn't change a MIDI setting on you.
deepminddark
  • 28
  • I <3 my Tempest.
« Reply #823 on: July 06, 2017, 07:53:03 AM »
Please take a look:
All midi cables (IN/OUT) and USB unplugged.
You can see / hear the difference watching DSI video:
https://youtu.be/b7FwkTSeUyA?t=137
Please compare these videos. Also please note that bars also speed up on my video.
« Last Edit: July 06, 2017, 08:44:16 AM by deepminddark »
Tempest for life.
deepminddark
  • 28
  • I <3 my Tempest.
« Reply #824 on: July 06, 2017, 08:09:02 AM »
Other issue which i found is according to changing sounds on the pads.
Try to do this:
1. Push A1, set (for example) User 2 folder / Sound X
2. Push A2, set (for example) Misc folder / Sound X
3. Go back to A1 and try to change your sound on this pad
4. Go back to A2 and try to change your sound on this pad
*Please do these steps using knobs under OLED Display.
As you can see, folders sound changed to other with other sounds. On my tempest it’s Perc folder with first sound on the list.
How it's working on your side?
Video attached below:
« Last Edit: July 06, 2017, 08:31:52 AM by deepminddark »
Tempest for life.
RobH
  • 464
« Reply #825 on: July 06, 2017, 08:56:46 AM »
My click seems to be working as nomal. I'll look at the rest later
deepminddark
  • 28
  • I <3 my Tempest.
« Reply #826 on: July 06, 2017, 09:07:20 AM »
RobH and others... could you share videos with your "Click", bar speeds and reported issues with changing folder sounds on your TEMPESTs?
Okay so... "click" and bar speed desynchronised after Format Flash drive - this is a reason of the issue.
Please try to do it on your side:
1. Please put both "Shift" buttons & "System" button
2. On Menu please select 8. Format Flash drive
3. Restart and check your "Click" speed.
Btw. Issue with changing sound folder really exist after update to 1.4.5.14 OS version. I downgrade OS to 1.4 and everything works fine. So this is a real bug of 1.4.5.14 OS.
Dear Dave / Roger, could you fix these issues? I'm very confused at the moment.
« Last Edit: July 06, 2017, 10:20:49 AM by deepminddark »
Tempest for life.
RobH
  • 464
« Reply #827 on: July 06, 2017, 10:51:54 AM »
We don't usually bother to make videos of things that are not broken and rarely even if they are.
I don't want to lose any work right now so I'm going to pass on formatting my flash and i'd rather not have my Tempest not be in action if there is a bug  as i've a lot going on right now but i'm 100% certain that Carson will format the flash on the office DSI Tempest to see if there is a problem with the click Dsync'ing.
Yes when i follow your guide to change a sound then go back to the original pad the sound folder changes, i'm not sure whether this is actually worth trying to solve or not its not something that really personally i would ever think about i'd just scroll to the folder i wanted without even thinking about it. Again speak to Carson its either an easy fix or something that will just have to be as its not really effecting anything other than you have to turn the knob again.
Welcome to the beta.
edit - Also Dave and Roger don't have much to do with the forum side of things with the beta there is little point in mentioning either, Carson is out DSI man, he will help you with any beta business.
« Last Edit: July 06, 2017, 10:53:44 AM by RobH »
cbmd
  • 505
    • Sequential
« Reply #828 on: July 06, 2017, 11:51:14 AM »
The cause of the behavior with the click is due to the default initialized beat being cleared when the flash drive is formatted.
As such, you will need to save a new initialized beat file through the debug menu. To do so, set up a beat with the default sounds and time signature you prefer. Hold both SHIFT buttons and press the SYSTEM button. Navigate to the SAVE NEW INIT BEAT menu item and select it. press the left most soft button below the Tempest's screen to save the current beat as the new initialized beat.
Product Designer
deepminddark
  • 28
  • I <3 my Tempest.
« Reply #829 on: July 06, 2017, 04:39:15 PM »
cbmd Thank you so much! This is what I expected from your side and needed to know... today i'm getting married, so i will check it tomorrow. Thank you for support. I found one else bug but i have to do more test to confirm this. Stay in touch! BIG UP!
Tempest for life.
« Reply #830 on: July 06, 2017, 04:45:14 PM »
Hehehe :D you remind me of me messing around at this forum before my wedding!Congratulations man!
deepminddark
  • 28
  • I <3 my Tempest.
« Reply #831 on: July 06, 2017, 05:28:54 PM »
Thank you!
Tempest for life.
RobH
  • 464
« Reply #832 on: July 06, 2017, 07:59:24 PM »
Man i feel bad now for giving you the Tempest beta introductional debut tutorial on your wedding day. I should defo have let Carson reply first xD
deepminddark
  • 28
  • I <3 my Tempest.
« Reply #833 on: July 09, 2017, 02:54:29 AM »
Best wishes from newlyweds! Finally i can confirm now. Issue resolved.  :D ;D :D ;) 8)
Tempest for life.
LucidSFX
  • 302
    • Soundcloud
« Reply #834 on: July 09, 2017, 11:39:10 AM »
Hey brother, I dont think your wife would approve your marriage as a bug report!!! Hahah!
For the honeymoon poc make sure you get a clean shot of the Tempest by the night stand. Sure fire way to get divorced!
Congrats bro! I wish you both a long an happy life;)
LucidSFX
current hybrid setup
2 x Technics 1200 MK7
Allen & Heath DB4
Allen Heath K2
Tempest
VirusTI2
RME UFX
Adam A7
SP2400 (on order)
Glenlivet 18yr scotch
« Reply #835 on: July 11, 2017, 02:26:52 AM »
What makes you so certain that deepminddark isn't the person on the right?  :)
« Reply #836 on: July 11, 2017, 05:23:28 AM »
Not certain, however:
LucidSFX
  • 302
    • Soundcloud
« Reply #837 on: July 11, 2017, 07:17:14 AM »
Social cue from 2nd photo
LucidSFX
Allen & Heath DB4
Allen Heath K2
Tempest
VirusTI2
RME UFX
Adam A7
SP2400 (on order)
LucidSFX
  • 302
    • Soundcloud
« Reply #839 on: July 11, 2017, 07:54:20 PM »
That track is sweet;)
LucidSFX
Allen & Heath DB4
Allen Heath K2
Tempest
VirusTI2
RME UFX
Adam A7
SP2400 (on order)
