Main 1.4.5.9 has been posted. This should fix the issue with voices dropping out.
cheers!
I hate to be that guy, but I just ran through my set with the new OS and I had a voice drop - though it only happened once in the hour set which is better than it has been. Carson, I've attached my project sysex file. Let me know if I should also file an official ticket.
The voice that dropped on this run through was voice 5 (pad a9) on beat 5 ("Merlin"). This specific voice on this beat is the most common one that drops for whatever reason - almost half the time when I get to this beat (it's a half hour into my set), voice 5 is not working. About 25% of the time the partner sound (a10) on voice 6 goes too. As mentioned in my previous posts, I've had voices 1 and 2 drop on other beats but never (to my recollection) voice 4.
Other common voice drops in this project (about 25% of the time individually, though not on this run-through):
beat 3, voice 1 (a12)
beat 3, voice 2 (a4, a11)
beat 3, voice 3 (a5, a13)
beat 4, voice 2 (a11)
beat 5, voice 6 (a10).
Project-wide details (beats 1-7):
voices 1-4 are all assigned in every beat and individually patched out the back. Voices 5/6 are assigned, but un-patched - ie: they play through the mains.
90% of the voices are either played live or triggered via midi so there aren't really sequences for you to press play on these beats
All the above is only for beats 1 -7, ignore the rest, they're not being used in my set so the patching doesn't apply and I can't comment on their behavior.
After installing the new Os I re calibrated my oscillators btw.
