Hey all,
Here's an updated list of the remaining bugs:
· If you accidentally hit the 16 Beats or 16 Mutes button first, when trying to enter 16 tunings or 16 Levels mode, the Roll function automatically disengages – mode changes should happen upon the button’s release in order to prevent this.
· In 16 Tunings mode, when the sequencer is stopped, both adding and releasing notes interrupts the Arp causing it to reset and fall out of sync.
· In 16 Levels mode, when the sequencer is stopped, the Arp allows notes to be triggered outside of the selected quantize value, which creates undesirable flams when trying to depress multiple notes at once, or when adding new notes to the arpeggio. Also, both adding and releasing notes interrupts the Arp causing it to reset and fall out of sync.
· When recording with the Arp in 16 Levels mode, the held pads blink in succession with each note trigger as expected; but after the first pass of the sequence is recorded, only pad 16 blinks. *In all other Arp modes, the pads continue to blink in the order they were depressed/recorded as expected.
· When switching beats on-the-fly, the first step of the sequencer-out is consistently late; so if you're triggering a sample loop on the one, every time you switch beats on the Tempest, it will be out of sync for the first pass. *This is an invasive fix.
· Tempest starts one midi clock late or early depending on various conditions of the sync source or Tempest modes. *This is an invasive fix.
· If you hold 'Shift' and turn the Compressor knob to get into the compressor menu, you can no longer get back to the Mixer screen.
· When Slider Mode is set to 'Real-time', only FX1 Slider is affected. FX2/3/4 sliders are always 'Step' regardless of this parameter setting.
· Using Mod Paths for external MIDI sound control results in intermittent affect on the sound. *Causes are unclear, but the bug occurs more frequently on playback of a Beat with many sounds.
· When playing a Beat containing held notes of an ADSR sound, if you turn on Bank B while 1) a note is playing and 2) a different sound is selected, the playing note's pad sticks on.
· LFO sync drifts when set to either 'Beat' or 'Play', and dotted eighths remains missing from the sync options.
· The sequencer-out still doesn't trigger notes in real-time: i.e. it only sends trigger information after the sequence is recorded, which essentially means that you're recording deaf.
· Beat roll still doesn't swing.
· A sound folder is still need to correspond with the pad name "Synth".
· Duplicate files appear when scrolling through the Beat and Project Folders in the Load File screen.
· Similarly, if a file is deleted from a folder and the following folder has a greater number of files present, navigating up (folder 2 -> folder 1) to the folder which the file was deleted from causes the last deleted file from the folder to be displayed as the last file in the folder. The file cannot be selected.
· Exporting an individual file from a file list will transmit the wrong file from the folder.
· When adding or copying steps via the Events Screen, the Pad lights do not correlate correctly in 16 Time Steps mode.
· If slaving a playlist from MIDI clock received over DIN MIDI and starting at location 9.1.1 or higher, Tempest starts playing from the wrong position. Syncing from MIDI Clock over USB works fine.
· In 16 Mutes mode, on the Pads screen, although you are still able to select a sound (holding shift and hitting a pad) it is not reflected graphically on the display. This could be fixed if the display matched the style of the Mixer screen.
· The Mute/Solo/Delay buttons should perform their functions in both the 16 Mutes/Pads and 16 Mutes/Mixer screens.
· Mutes “All On” should be available on the mixer screen in both 16 Mutes and 16 Sounds Mode.
· The “Undo All Sounds” functionality needs to be made simpler or otherwise removed.
· The Tempest can enter a state – usually after updating – wherein two or more sounds cannot be triggered at the same time. Resetting the system settings seems to fix the issue, but only temporarily. The Tempest can revert back to this state, cause as of yet unknown.
· When you set System > UI Preferences > Solo/Mute behavior to 'Seq only', if you mute a pad that contains a sequence and then attempt to play that same sound live in 16 Tunings mode, turning the Mixer Level knob causes the sound to cut-out.
I'll keep adding to this list as bugs get reported and confirmed. Thanks for all your hard work everyone. Now wouldn't it be something if we could take the better part of these OFF the list... Keep making noise, y'all (wink).
Cheers!
