I finally backed up my patches. Here's the patch file:
https://toykeeper.net/tmp/music/TK_Karpluck_String.midiThis is free to use... but if you use it, I'd really like to hear what you make.
The performance controls are:
- aftertouch: vibrato
- touch strip: feedback
- mod wheel: distortion
- pitch bend wheel: pitch and feedback
- filter knob: brightness
- legato play style: change pitch but don't pluck string
So... mess around with these to get different sounds. Like, plucking vs bowing, etc. I recommend turning latch on for the touch strip, and experimenting with overlapping vs non-overlapping notes to build and break resonance. With feedback up, long notes can fade and recover by using the pitch bend wheel.
It should be in tune for at least 3 octaves, but you may need to adjust the correction factor to match your individual instrument. That's the "Note Num to Feedback Tune" in the mod matrix. Other settings may need to be changed too, on a per-instrument basis. I find mine makes different sounds when it's cold than it does when it's warmed up.
If you play an octave up or down legato style, it likely won't change the sound much. Play some intermediate notes though, and the octave change is more effective.
Anyway, this can be sent to the Pro 3 the same way as any other patch. If I recall correctly, just navigate to the slot you want to save to, then send the patch file via midi from a computer. It may also be necessary to save afterward, same as if you had created the patch manually. Has been a while since I loaded an individual patch.
