I am currently on 1.2.10b, and i have a problem : on the GOLBAL MIDI OUT parameter : I want the P6 not to send midi, so I thought switching it to "PLY" was the solution. But no : when I change the main volume, it sends a volume midi message. So I switch the parameter on "MID", cause I use USB midi. Works fine, the messages are probably sent to the MIDI (din) outputs, and nothing is sent via USB midi.
BUT : when I switch off and on the P6, this global parameter goes back to original setting (BOTH). Which means that my changes on globals are not saved... I have to re-change this each time I with on the machine.
So I wanted to go back to the os 1.1.0, which was very stable for me. But the install always fails : a "6" is showing at the end, freezing. press "write" button, then animation looping forever. Switch off and on does not solve the problem. So : IMPOSSIBLE TO INSTALL OS 1.1.0 !! How come ?
And how can I fix the globals saving problem....?
Thanks.....
Vince
