Share Your Wavetable Thread
Re: Share Your Wavetable Thread
« Reply #20 on: December 05, 2020, 01:20:22 PM »
Very good initiative!
I add one thing concerning the wavetable. The pro 3 only offers a resolution of 16 cycles which is not much, compared to some plugins which go up to 512 cycles.
I am thinking of reporting comparisons to Sequential to inform them of the importance of allowing higher wavetable resolution.
Because, like an image, a wavetable has a resolution, the lower the resolution, the less detailed the rendering will be.
Effectively 16 wave cycles in the Pro offers little resolution. It’s a shame.
Anyway, trying to create an alternative to edit and load, share wavetables would be great! Total supports! :)
« Last Edit: December 05, 2020, 01:24:51 PM by lvbeethoven »
Tiptop Audio Buchla System
ASM Hydrasynth
Endorphin.es Shuttle System
Soma Pulsar23
Sequential Prophet 6, Rev2, Pro3
Waldorf Quantum
Akai MPC One
Moog DFAM
Arturia Microfreak
Beringher Model D
Elektron Digitakt
Korg Nautilus
« Reply #21 on: December 05, 2020, 01:56:02 PM »
Some wavetables that I share
They all come from the Xfer Serum plugin... The table bird is a hissing bird.
I am also thinking of doing another one from the Xfer Serum plugin. This time using only the "Warp" functions of one of the two oscillators. Because indeed these functions allow you to create mirror effects, PWM, FM, Quantize etc.
What is unfortunately not possible to do on the Pro 3.
These functions make it possible to have a more or less characteristic effect on the wavetable. Extracting the effect produced by these transformation modes should surely give interesting results with the Pro 3.
« Last Edit: December 05, 2020, 01:59:53 PM by lvbeethoven »
ASM Hydrasynth
Soma Pulsar23
Waldorf Quantum
Akai MPC One
Moog DFAM
Arturia Microfreak
Beringher Model D
Elektron Digitakt
Korg Nautilus
« Reply #22 on: December 24, 2020, 07:24:20 AM »
Note: This is not an audio wavetable. If you use it as an audio wavetable, you won't hear anything.
This is a wavetable that's designed for use in LFO mode, but it doesn't "oscillate" in the traditional sense. It is a Pro 3-based partial emulation of the Doepfer A-144 Morphing Controller eurorack module (http://www.doepfer.de/a144.htm). This wavetable emulates Out 1 of the A-144.
In a sense, it's a 0-frequency triangle LFO whose phase you can control with another modulation source. Each of the 16 reference waves is a constant level (which is why it doesn't make sound).
To demonstrate how it works, here's a simple recipe, starting with Basic Program:
(1) Select the Morph wavetable and turn on LFO mode for Osc 3
(2) For Osc 3, turn off Key Follow
(3) Set Osc 1 Level to 64 and Osc 2 Level to 0
(4) Assign Osc 3 to Osc 1 Level at amount of -64
(5) Assign Osc 3 to Osc 2 Level at amount of 64
(6) Assign slider to Osc 3 Shape Mod at amount of 127
(7) Set Osc 1 and 2 shapes to taste
Now play as you move the slider back and forth.
« Last Edit: December 24, 2020, 07:55:37 AM by chysn »
RAFH
« Reply #23 on: December 29, 2020, 07:02:49 AM »
Here is the juno 106 wavetable that I posted in the other thread!
* Please note , this table originally only had 11 waves, I added the additional 5 by copying the 11th, and then modifying each wave slightly.
Sequential Pro-3, Elektron Analog Heat MK2, Elektron Analog RYTM MK2, Elektron Analog Four MK2, Pioneer Toraiz SP-16, Behringer TD-3, 104hp Modular Synth w/Mutable Instruments modules, 48hp Modular FX box with Intellijel Rainmaker and Audio I/O, Eventide H9 MAX
« Reply #24 on: January 01, 2021, 08:37:16 PM »
This experimental 32-waveform wavetable takes advantage of the Pro 3's use of downsampled waveforms at different note numbers (that is, each Pro 3 wavetable is actually four independent wavetables). Rather than using versions of the same waveform, as is the convention, it uses two radically different waveform sets.
If you set Transpose to -1, the low third of the keyboard has a harmonically-rich wavetable, and the high two-thirds of the keyboard has a more fundamental wavetable built on rippled sine-like waveforms. Both wavetables were generated with Serum, and stitched together with my home-brew wavetable generator software.
« Last Edit: January 01, 2021, 09:52:24 PM by chysn »
« Reply #25 on: February 17, 2021, 03:10:38 PM »
D'oh! My split wavetable post above has the wrong file. You can download the wavetable for any position here:
http://wav2pro3.beigemaze.com/?11e99c865e334bd4cd644e5d382f6034
« Reply #26 on: February 22, 2021, 08:15:13 PM »
Simple single-oscillator square waves intermixed with two- and three-oscillator complex waveforms generated by my Commodore VIC-20 (real, not emulated)
http://wav2pro3.beigemaze.com/?84b169ef9b3aa8121ddfbe98da48b5e1
« Reply #27 on: February 27, 2021, 02:30:14 PM »
MicroBrute - Sweep of the Metalizer knob with the filter wide-open.
http://wav2pro3.beigemaze.com/?0d2506b20cab37968fcd51eadd0dbb01
« Reply #28 on: March 01, 2021, 08:12:37 PM »
I like this one a lot. It's a conversion of one of the Vital presets called "Drink the Juice." It's an awesome vocal-type wavetable.
http://wav2pro3.beigemaze.com/?3794ea2ea3def45efe43c74daab678e7
« Reply #29 on: March 26, 2021, 09:10:55 PM »
Here's the famous Wilhelm scream in wavetable form. You've heard the Wilhelm scream in Star Wars (and, indeed, just about every George Lucas film), Toy Story, Aladdin, Game of Thrones, and so on and so forth.
http://www.wav2pro3.com/?0d6c0c713aea9ef89afad7cb800c44e7
« Reply #30 on: April 02, 2021, 09:26:10 AM »
This is a selection of timbres from Milton Babbitt's classic Ensembles for Synthesizer (1964). These are primarily taken from low-frequency drone-ish timbres, so this wavetable is best played low on the keyboard.
http://www.wav2pro3.com/?5402f9b3c6da6a45c94c34f9b1c73443
« Reply #31 on: May 14, 2021, 11:05:31 AM »
Most likely already known, there are toons of waveforms available from adventurekid. Some of them contain much more as only 16, in that case you have to choose and/or experiment.
https://www.adventurekid.se/akrt/waveforms/adventure-kid-waveforms/individual-folder-downloads-of-the-akwf-pack/
I've created some out of these.
Pro 3 SE #295
macOS, Logic X, Eurorack
https://www.youtube.com/user/daSunBrain
« Reply #32 on: May 18, 2021, 06:45:05 AM »
This wavetable is insanely good. Thank you!
« Reply #33 on: July 05, 2021, 12:30:11 PM »
Waldorf Micro Q Wavetables (32 waves split across 2 wavetables). I hope you find them useful:
http://www.wav2pro3.com/?43585443bba50970b1e83f7ecd133b4f
http://www.wav2pro3.com/?8896a4a665df9cfd2410ebe4a8028cde
drew_n
  • 246
« Reply #34 on: July 08, 2021, 12:15:30 PM »
32 new wavetables that occupy slots 33-64, plus 128 new presets to mess around with. Enjoy!
https://www.sequential.com/new-pro-3-wavetables/
« Reply #35 on: July 10, 2021, 04:48:50 AM »
hey ^^ these are great and what a great update also! thanks sequential  :)
« Reply #36 on: July 12, 2021, 01:45:15 PM »
Is there a list of names for the new Wavetables or even for all of the Wavetables in the Pro 3 in general. I don't even think the manual has these.
« Reply #37 on: July 12, 2021, 02:38:36 PM »
The names for the new Pro 3 wavetables are in the filenames and stored in the SysEx files, of course. Since it's not possible, as far as I know, to dump the wavetables or the names, yet, I typed them in (any errors for 1-32 names are mine ;-). The list below for 33-64 were generated from the newly posted Pro 3 wavetables.
Code: [Select]
====Pro 3 Oscillator 3 Wavetable Names
Note: 1-32 included in base Pro 3 OS.
33-64 from new Pro 3 Wavetables made available in July 2021.
 1: Sequentl
 2: WaterFon
 3: Quad Sqr
 4: NastyWav
 5: A-E-AH-O
 6: Drawbars
 7: Chebyshv
 8: EightOh8
 9: MadRingy
10: BigSteps
11: BellTree
12: Spindles
13: Primes
14: WhoKnows
15: Fem Vox
16: Fat Saw
17: ResoRezz
18: Low Linn
19: zZippeRz
20: MultiVrs
21: Pot Gong
22: Old Bell
23: DigiWave
24: X-former
25: 16 Sines
26: Noisy
27: Static
28: SinePwrs
29: Wolfgang
30: D-Xed
31: Smoothie
32: RingyMod
33: WeirdWav
34: TAUNoise
35: TOMDrum
36: FreqShft
37: BBDFlngr
38: EQPhaser
39: Digimetl
40: SalKeyLP
41: Additive
42: MetaSyn
43: BPSaw
44: TauSQR
45: OddyRez
46: IIxMode1
47: IIxMode4
48: IIxHybrd
49: OddMix
50: Formant
51: Britebel
52: Darkbell
53: JustRude
54: MetlComb
55: CombFilt
56: Piano
57: Dyno
58: Reedy
59: Stick
60: Reedy2
61: Clav
62: Aliasing
63: Animated
64: Pro3
« Reply #38 on: July 13, 2021, 08:27:35 AM »
Code: [Select]
 1: Sequentl
 2: WaterFon
 3: Quad Sqr
 4: NastyWav
 5: A-E-AH-O
 6: Drawbars
 7: Chebyshv
 8: EightOh8
 9: MadRingy
10: BigSteps
11: BellTree
12: Spindles
13: Primes
14: WhoKnows
15: Fem Vox
16: Fat Saw
17: ResoRezz
18: Low Linn
19: zZippeRz
20: MultiVrs
21: Pot Gong
22: Old Bell
23: DigiWave
24: X-former
25: 16 Sines
26: Noisy
27: Static
28: SinePwrs
29: Wolfgang
30: D-Xed
31: Smoothie
32: RingyMod
33: WeirdWav
34: TAUNoise
35: TOMDrum
36: FreqShft
37: BBDFlngr
38: EQPhaser
39: Digimetl
40: SalKeyLP
41: Additive
42: MetaSyn
43: BPSaw
44: TauSQR
45: OddyRez
46: IIxMode1
47: IIxMode4
48: IIxHybrd
49: OddMix
50: Formant
51: Britebel
52: Darkbell
53: JustRude
54: MetlComb
55: CombFilt
56: Piano
57: Dyno
58: Reedy
59: Stick
60: Reedy2
61: Clav
62: Aliasing
63: Animated
64: Pro3
THANK YOU! :)
« Reply #39 on: November 14, 2021, 08:26:10 AM »
With much thanks to forum member Soundquest, who took the time to record all of the Evolver waveforms for me, I'm happy to make available Evolver Set 1, which includes waveforms 1-16. Over the next couple weeks--as time permits--I'll continue with this project, which will eventually span six Pro 3 wavetables.
http://www.wav2pro3.com/?9309880ca7248b61b11caa42bf31f93c
