I thought it might be useful to share the README here, which includes a listing of the patch titles and installation instructions. Thanks!
PROPHET REV2 AUDIOCOOKBOOK.ORG EXPERIMENTAL PATCH SET
VERSION 1.0.2
Congratulations on purchasing the Prophet REV2 AudioCookbook.org Experimental Patch Set (version 1.0.2). The set includes 128 completely original patches developed on a 16 voice Prophet REV2. All 128 patches have been recorded and can be heard here:
https://soundcloud.com/ostraka/sets/prophet-rev2-audiocookbookorg-experimental-patch-setThe bank is comprised mostly of experimental patches and sound effects, but also includes patches manually developed through a conceptual process, and some that were created as conventional sounds to fulfill a specific utility.
INSTALLATION
Start by backing up all of your patches in the four user banks on your Prophet REV2. This can be done the Globals menu under "Dump All Banks" and system exclusive librarian software on a computer. I suggest SysEx Librarian (
https://www.snoize.com/SysExLibrarian/) on Mac, or MIDI-OX (
http://www.midiox.com/) on Windows. Currently the patches load into User Bank 1. A new version of the patch set is in the works that will have separate files that load into each of the four User Banks so that you can choose which bank to use. All updates to the patch bank will be made available as a free download to current customers.
1. First connect your REV2 to your computer with system exclusive librarian software.
2. Open your software and put it into the "record many" mode. Press write while in Globals/Dump All Banks to make your backup.
3. Now use your librarian software to send the Prophet REV2 Patch Set to your REV2. Connect the REV2 to the computer via USB or through a MIDI interface and choose the new patch bank in the librarian.
4. Enter the Globals menu on your REV2. Press play in your sysex librarian to send the patch bank to your REV2.
HOW THE PROPHET REV2 EXPERIMENTAL PATCHES CAME TO BE
Over the last few years I’ve been developing Max for Live devices to manipulate hardware synthesizers. These include the Yamaha TX81Z, PreenFM2, and most recently the Sequential Prophet REV2. I designed these tools to help me uncover new territory in the sonic landscapes of these instruments. This has led me to create libraries of unique, bizarre, fascinating, and evolving patches. I typically use these techniques, and sounds for musical projects, commissions, and performances. I have been thrilled with the results I’ve been getting on the Prophet REV2, so I decided to create a bank of experimental patches to share with the REV2 community.
These patches were created using several different techniques:
1) A custom Max for Live device was used that randomizes and/or slowly degrades patch parameters over time. Once an interesting patch is created this way the patch is edited to make it suitable for performances and productions. Most of the special effects and experimental patches were produced this way.
2) Starting with a initialized patch, hands on experimentation was used until interesting sounds emerged. For example: experiment with self-oscillation using the 4-pole filter. Some of the tonal patches were created with this technique.
3) A conceptual framework was identified to create the patch manually. For example: make a monophonic lead tone that responds to velocity and aftertouch, etc. This is how many of the more conventional patches were developed.
ALL THE PATCHES INLCUDED IN THE PATCH BANK:
1. Delayed Lead
2. Bells Out Tune
3. Pseudo Marimba
4. Wide Piano Spread / Keston Piano
5. Degraded 0.1a
6. Wide Saws
7. Cats on L5D / Locusts on PCP
8. Weird Gurgles A / Weird Gurgles B
9. Fixed OSC Mods / Fixed OSC Mods B
10. Vibranova / Vibranova B
11. Creepy Thundar / Creepy Thundar B
12. Teleportation
13. Dante's Inferno
14. Synced 5ths
15. Glitch Harp
16. Glass Mallets
17. Wobbly Pluck / Wobbly Pluck B
18. Ghost Glitch / Ghost Glitch B
19. Bucket O'Maggots
20. Spitty Clav
21. Ring Mod Vibes / Reverb Vibes
22. Trimorphosis
23. Pseudo Sho
24. Sick & Disonant
25. Atonal Glitch Pad
26. Reset & Catch Fire
27. Presure Static
28. Bb Drone Pad
29. Talky Metalic
30. Woody McRimba
31. Pulse Pad / Muddy Pad
32. Keston Arps
33. Broken Voice Chips
34. Clicky Kimball
35. r0BotSPe3K 0.72
36. Malignant Spirits
37. Dirty Needles
38. Mono Lead Arp Stack
39. Shape Morph Poly
40. PWM+OSC Sync
41. What a Mess
42. Vibro Organ
43. Grand Pad
44. Morse Code On Acid
45. Pressure Shape
46. Junkyard Steel
47. Over Modulated
48. Juno-106 Bass
49. Phase Phreak
50. Piercing Transmit
51. Pitch Wheel EBM
52. Slow Slew Gated
53. Tri Shape Mods
54. Horror SciFi
55. ANdr0id L4nGUaG3
56. Keston Split
57. Key Trckd LFO1
58. OSC Slop Wheel
59. Xtreme Frogz
60. 2600 Bleep Pad
61. Thin Metal
62. Chaotic PercSeq
63. Balloon Madness
64. Traffic Jam
65. OOT Crackles
66. Predictably Out / Of Tune Sequence
67. 8bitPulsePtchSwp
68. Spastic MOD Matrix
69. Gated OSC Sync
70. OSC Sync Slew
71. Fortran Gated Seq
72. Gated Shp Pan LPenv
73. Keston Soft Piano
74. Gated Looped ENV3
75. Well Shaped Triangle
76. HPF ENV VEL TRK
77. Basic Square Bass
78. Resonant Dream Pad
79. Sawtooth Delay Mod
80. Slippery Saws
81. Accelerating LFOs
82. Square Lead Clean
83. Heliotrope SFX
84. Formant Like GateSeq
85. Power Tools
86. Sentient Insect
87. Formant Simulator
88. Pressure Scream
89. Wet, Wide & Wobbly
90. Dirty 808
91. Ode to Hades
92. Heaven's Gate
93. Toxic Mist
94. War Machine
95. Po1y Wind
96. Palm Flower
97. Wait For It
98. Pipes Wheel=Tone
99. Gated 5ths Pad
100. Space Bikes
101. Space Bike Alarm
102. Keston Piano
103. Circus of Pain
104. Fixed OSC Mods
105. Ominous Metal Door
106. Laser Chimes
107. Stereo Vibes
108. Fizzy Pressure
109. NoRhymeOrReason
110. Classical Saws
111. Room Full Of Talkers
112. Fixed OSC Sync
113. PulseSawtooth Pad
114. Del Rate Press SFX
115. Afterburner
116. Pressure Detune
117. OSC Slop on Att-Rel / Slop on Att-Rel
118. Satanic Cellos
119. Asp Tongue in Larkic
120. Slow Ramp
121. Self Oscilotomatron
122. Noise to Pitch Mod
123. Crazy Reso Sweep
124. Try Gated or Not
125. Spicy Gated Pad
126. Bubbles A / Bubbles B
127. Xenakis Pad
128. Fragile Gloss
