Hello everyone!
I noticed an issue with my Prophet Rev 2 recently. When I am in unison mode (8 voices) and add the onboard reverb, it really tends to clip a lot. Has anyone encountered this problem too? Is there a solution to this? Thanks in advance!
Confirmed.
Selecting basic patch, turning on both oscillators to sawtooth, oscillator mix at 50% (64), selecting Unison (set to 8 or 16 voices in menu), selecting Reverb effect with 50% dry/wet signal mix, reverb tone at 64, reverb time at maximum, results in severe crackling due to ADC digital clipping of the input signal.
Turning down Program Volume parameter doesn't remove clipping.
Turning down the Sustain level in the Amplifier section doesn't remove it either.
The only thing that will temporarily remove the clipping is lowering the Env Amount in the Amplifier section.
All other effects show heavy distortion of the signal, but no digital clipping.
