Thank you for all the compliments... it means a lot, and is a great part of what makes me continue on with this bank, perfecting all and every sound to the best of my abilities.
With that said though, I must confess that having the bank ready for the first of december was perhaps a bit too confident... I still have 32 programs to make, and after that, I'm to finetune all 128 of them since some still lack programming for some of the physical controls (pressure, velocity, pedal, modwheel etc.)... a few also need to have something on the B layer since they currently only use layer A (it's my goal that every single program use both layers, with layer B being an "add on" that can easily be switched out if you need the extra polyphony, or want the added FX switched off... i want to utilize all the juice of the REV2 for every program, simple as that). The only thing that will remain empty is the poly sequencer data... this is simply because anybody would want to make their own sequences, and not use premade ones... there is no reason to have anything in there... but they will be cleared, and ready to go, so that you do not have to deal with that when you want to create a new sequence for a program (Sequential have still not fixed the problem with having to constantly copy sequence A to B via the misc menu if you use a stacked program).
So... I need a bit more time to finish this bank... also, december is a busy month, so I'll just say that it'll definitely be finished some day within december... I also need to make a thorough manual for listing the programs and describing them, and how to use them, as some of the programs won't come alive until you start moving controllers, and some even need to be used in a specific way that will need explanation. I may create this document AFTER the release of the bank though...
