hi everyone, some little question about mod and expression pedal.
1 ) For a global use, I realised that you can not assign the expression pedal to the modwheel in the global settings (
?! ) that's a pity, but have you a trick to do the job in a global way ?
2 ) When I assign " LPF " to the pedal in the global settings, I don't understand what I really control and wich knobs it affects, is it a mix of the cut off and the resonance and other things ? Because when I turn the cut off all the way up at the same time it's really different and less harsh that what the pedal does.
3 ) Not a big deal, but is it normal the modwheel affect the LAYER A when you are playing and editing the LAYER B ? ( in multimode ON )
- For example, when you directly play on the REV2, you play and let run an arpegiated chord on LAYER A.
And when I switch and play on LAYER B ( the LAYER A continu to run only when you are in multimode ON ) the modweel affect the LAYER A too...That can be sweet, but if you just whant to affect the layer you are playing I don't know what to do.
thank y
u !
