Recall last Preset/Setting after reboot
« on: May 13, 2018, 01:36:00 PM »
New to the Rev2 and I’m wondering why when I turn off the unit and turn it back on, it shows the last patch used for a split second, then REV2 logo show up and then switches to a different random patch.
Is there a way to set it up so it boots up with the last patch used?
Apologies if this has been discussed already.
jg666
  • 557
Re: Recall last Preset/Setting after reboot
« Reply #1 on: May 13, 2018, 02:08:12 PM »
It will always start up with the same patch unless you change the startup patch. If you go into Globals and then back out of Globals then power down, it will start up with the patch that you was on when you went into Globals.
« Reply #2 on: May 13, 2018, 11:48:33 PM »
Wow that works! Was that documented in the manual? If not, are there other hidden tips and tricks?
shiihs
  • 103
« Reply #3 on: May 14, 2018, 05:28:00 AM »
I collected some tips and trips from the forum here: https://github.com/shimpe/rev2/blob/master/tipsntricks.txt
Use at your own risk ;)
links:
