Hi All,
I am having trouble sending CV out to control tempo of Roland SH101 sequencer. Has anyone on the forum had success with this? Currently I am using a quater inch cable from the Rev 2 sequencer connecting it to the "EXT CLK IN" input of the Roland SH101
Should I be using a different cable to connect to SH101 CV in input? Are there any other setting that I should change on the Rev 2 to send clock out signal?
Apologies if I am being unclear I am a noob
I'm sorry but it is not possible to do what you suggest. The REV2 Sequencer jack is for connecting a foot switch pedal to start/stop the internal sequencer of the REV2. It is not an output to control an external one.
Although it is possible to start/stop the REV2 sequencer with an audio signal, or to control the Trigger/Gate of the envelopes (by selecting the right Pedal mode in Globals) with an analog trigger pulse from an external device (such as a drum machine with Trig Out). But the REV2 cannot control the tempo of an external analog sequencer. (BTW, thank you for making me discover that feature when I read the manual about the Sequencer Jack input of the REV2)
Moreover, the EXT CLK IN of the SH-101 is expecting an analog clock signal. It is not a CV (control Voltage) input per say.
You would need something like this to convert electrical/digital signals into the proper ones:
https://www.roland.com/global/products/sbx-1/
